Help!
I have a 1993 hatchback LXI and stupid as it may sound I don't know what the engine size is. Surely there is a way to figure this out?
D16A7 which isn't in any of those lists. Am I getting this wrong?
I don't want to be a d!ck, but you can google that.
Honda D engine - Wikipedia, the free encyclopedia D16A7 (Basically a D16A6 that came without a catalytic converter) Found in: 1988–1991 Civic 1.6i (GTi) in New Zealand 1988–1989 Civic models in Europe(ED4,ED7) 1995 Civic models in New Zealand (EG4) 1988–1995 Models in South Africa 1994 Civic GTi (New Zealand) (Various Differences and Increased Output) Ballade SH4 and SR4 ( D16A7 / EE4 ) Bore and Stroke: see D16 Series Engines Displacement: see D16 Series Engines Rod Length : 137 mm Compression : 9.6:1 Power : 117 hp (87 kW; 119 PS) at 5,900 rpm Torque : 13.9 kg·m (136 N·m; 101 lb·ft) at 4,800 rpm Valvetrain : SOHC, four valves per cylinder ECU: PM6 (OBD-0) / P27 (OBD-1)? Fuel Control : OBD-0 Multi-point PGM-FI, OBD-1 (NZDM) |
Thank you. I had no idea what I'm doing.
