help:99 civic si code p1336
Old Jul 3, 2009 | 08:18 PM
skyvang's Avatar
Default help:99 civic si code p1336
i was driving and my timing belt snap..so i replace a new timing belt and this p1336 engine check code pop out.. i was wonder what i need to fixed? plzz help me, let me know thanks..
Old Jul 3, 2009 | 10:49 PM
Did you forget to reconnect the CKF sensor?
Old Jul 4, 2009 | 11:22 AM
skyvang's Avatar
thanks for the help, i check the crank sensor and it is connected. I think my crank sensor went bad...
Old Jul 4, 2009 | 12:06 PM
You need to remove the crank pulley again to inspect the CKF sensor or to replace it. First carefully inspect the CKF connector for damage or corrosion.
Old Jul 18, 2009 | 01:56 PM
skyvang's Avatar
i replace to a new crank sensor, the engine check light is still on..i was wonder, is it have to do with my timing? thanks for the help..
Old Jul 18, 2009 | 02:45 PM
Could be a problem with the CKF sensor wires that run between the connector and the ECU. Also carefully inspect the connector itself.
George4242
Nov 19, 2011 06:17 AM
jdtrio
Mar 17, 2010 02:52 AM
ioang26
Dec 30, 2007 03:33 PM
ktownjeep
Jun 20, 2007 01:40 PM
Black Magician Hiro
Jan 15, 2005 08:47 PM
