HELP ME o2Senor problems 01 civic
I have a 2001 civic ex and its a automatic
i had the check engine light on and and it read both o2 sensors were bad so i replace both before and on catalic converter the one on the Cat does show anymore so its fine but the one righ after manifold it still says malfunction i just got another one and still Check engine please help me |
what is the exact code that its has? it could be a bad catalic converter
Could be a crack in the manifold maybe? Possible loose and/or corroded connection at the front o2 sensor?
Also, please try and post in the correct section. MOving to Mechanical Problems & Technical Chat |
Its not a cracked manifold and not a catalic i forgot code
but it says oxygen sensor bank 1 sensor 1:):):):):):eek::eek::eek: |
Post the exact codes.
