HondaCivicForum.com
-   -   help with my projector headlights (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/help-my-projector-headlights-27438/)
lookitzxai Aug 17, 2006 08:48 PM
I recently got a projector headlight for my 95 civic dx.....but the left headlight is kind of low (pointed towards the ground) whenever i'm driving at night. Does anyone know how to adjust it so that its raises up a little. My friends said there should be a screw on there or something to adjust it, but the only screws i saw are on the high beam (inner bulb on the headlight). I'm trying to adjust the center bulb to raise it up a little. Help anyone?
fglaustin Aug 17, 2006 09:11 PM
RE: help with my projector headlights
unless this is all different with the lexan lights - the entire unit moves for adjustment. look in front of the headlight and look for a screw at the middle of the top (or bottom) for adjustment
mill$civic Aug 17, 2006 09:12 PM
theres 2 adjuster knobs or screws or bolts on the back of your headlights, one to move the beam up and down and the other to move it side to side...play around with them and see what controles what, you need to do it at night because the beam moves VERY slowly so its hard to notice it move
lookitzxai Aug 19, 2006 12:23 PM
oh.....alright then.....there's a "x" shaped screws.....but i wasnt sure if it would adjust its....i thought it was gonna pull the headlight apart or something....i'll give it a try later and see what becomes of it.... thanks
