Here's a head scratcher...
Ok... when its pretty cold outside if i leave the driver's side door open for more than 3 seconds the seat belt light will begin to flash. When I close the door the "door light" does go out but the seatbelt light continues to flash????? The only way to make it stop is a re-start. I'm stumped.. any suggestions?
1990 si HB |
RE: Here's a head scratcher...
Does buckling your seatbelt stop the light from flashing? If not, the problem probably lies with the seat belt switch itself (see pictures) or the integrated control unit.
http://img341.imageshack.us/img341/1...ure0213ub2.jpg http://img247.imageshack.us/img247/4...ure0214xj5.jpg |
Nope... if I engage the seatbelt the light continues to flash... but when its not flashing the light works right with the seatbelt... I,C,U..?
The pictures show how to access and troubleshoot the integrated control unit circuit. Note that the test results may help to identify the faulty component.
http://img247.imageshack.us/img247/6...ure0218ku9.jpg http://img247.imageshack.us/img247/8...ure0219zd6.jpg |
Thanks for the help but all I get is2 little boxs with an x in them, "pictures" on my screen.. I'm on a work machine right now.. maybe i can access them when i get to the house..Thanks again....
If you are on a slow internet connection, the pictures may take some time to load.
Got the schematics.. Thanks again... (little late to break out the tester tonight though!);)
