HID Problem....Help
Wuts the difference between a H4-1 and H4-2 bulb and will it fit into any H4 socket?
RE: HID Problem....Help
if it's real HID's no the bulb will not fit in your H4 socket, you need ballasts with H4 connectors, a HID kit should come with them,
As for H4-1 and H4-2 the 1, is low beam only, and the 2 is low HID, and high Halogen(which will suck more then a vacume) |
for the H4-2 as long as i stay on low beam i get the hid output right or no?
ORIGINAL: MIkeyP for the H4-2 as long as i stay on low beam i get the hid output right or no? |
thing is they were the same price and i actually got the h4-2 bulb instead of the h4-1 and my car has a different light source for the high beams. Will me putting the h4-2 cause any serious problems?
when you say that you have a different light source for the high beams, what do you mean by this? so you mean a different source as in, the little halogen bulb that is on the H4-2? or a different bulb entirely?
I have a different bulb entirely for high beamand i ordered the H4-2.
And from what you said the H4-2 is a hid and high beam. So i wanted to know if putting the H4-2 would cause any problems, cause my last HID blew a fuse |
So do you have aftermarket headlights? i'm confused about the separate high beam? the factory headlights re H4, but if you have aftermarket ones they may not be H4, especially if they are the projector ones
i have a different bulb for my high beams and a different one for my low beams if that helps
no really... you're driving a civic right? what generation? if it's an EF then that explains it lol but i don't think that EF's use H4's
| All times are GMT -8. The time now is 12:55 AM. |
