High Idle
1997 Civic EX 4dr Automatic 178000 miles
After I have driven for awhile the idle wont drop down. When I am in park it sits a 2000 rpm. I know some honda have an air valve, or something, that you can adjust. Does not matter if the a/c is on or off. Also the idle doesn't kick up when the a/c comes on. Any help would be greatly appreciated. |
First check is to make sure the throttle cable goes slack and the throttle plate closes all the way when no one is pressing the gas. I think your model has a fast idle thermal valve on the thermostat housing, it is plastic and easy to get broken off. Take off the idle air control valve from the bottom of the throttle body and clean the air passage with spray cleaner.
This is a MAP controlled system, so basically air leaking into the intake from anywhere will cause idle speed to increase. |
Originally Posted by mk378
(Post 788429)
| All times are GMT -8. The time now is 01:15 AM. |
