HondaCivicForum.com
-   -   Honda Civic 93 starting problem (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/honda-civic-93-starting-problem-61625/)
chikna Feb 28, 2008 09:28 AM
Hi! I have a Honda Civic 1993 152000 kms. If I get to start it, it starts fine after it has warmed up but when I leave it for a long time, like leave it overnight, when I start it, the motor turns/crank and I struggle to make it start. spark plugs changed. Don't know what's wrong. Plus, the car smells gas but there is no leak anywhere, please help, I need a car to go to work. My speedometer won't work. Sometimes it works when the car has been driven a long time, say 15 minutes. Thanks for your help!
RonJ Feb 28, 2008 09:44 AM
RE: Honda Civic 93 starting problem
Is the check engine light ON?
The gas smell may be due to a flooded engine, which can lead to low compression and difficulties starting.
The cause of the difficult start may be bad plug wires, distributor cap, or rotor. Problems with the coil, igniter, fuel filter, or fuel pump are also possible, although I'd start with the items mentioned earlier.
chikna Feb 28, 2008 10:08 AM
thanks a lot bud!
the engine light is On once i insert the keys but goes away once i start the car. it doesnt stay ON ..
thx
RonJ Feb 28, 2008 12:05 PM
ORIGINAL: chikna
I suspect that the odometer and tripmeter work properly. If so, then your speedometer likely needs to be replaced.
chikna Feb 28, 2008 05:58 PM
wiring sequence for distributor cap civic 1993
mk378 Feb 28, 2008 07:47 PM
So you took your wires off, need to know how to put them back on? All Civics fire in order 1-3-4-2 going clockwise around the distributor looking at the top of the cap. There is usually a 1 on the cap next to where the wire to cylinder #1 goes, I think it is the one at about 10 o'clock. Cylinder 1 is the one farthest from the distributor.
chikna Feb 29, 2008 06:56 AM
ok so i put new spark plug, distributor cap and all wires in order car did start well. i drove about 60 kms n then parked my car but this morning when i tried to start the car it wont it was same as before. battery wasnt drained out for sure coz all my lights and etc were working. please let me know whts going on ...is it the fuel pump? \\
mk378 Feb 29, 2008 09:07 AM
Could be the main relay. You should hear the fuel pump (under the back seat) run to prime the lines when you turn the key on but don't try to start. Also when turning the key on but not cranking, the check engine light should come on for 2 seconds and then go out, the pump runs while it is on. Of course this test is only meaningful if you do it while the car is not wanting to start.
chikna Feb 29, 2008 10:56 AM
hey thnx a lot for replyin all my msg. i appreciate.
i did check that n there is no prob. with fuel pump coz fuel does run through the pump when i crank for 2 - 3 secs.
RonJ Feb 29, 2008 07:39 PM
You may be having a problem with the Fast Idle Valve:
http://img213.imageshack.us/img213/1...ure0607nm3.jpg
