Honda Civic DX 97 o2 Sensor Issue's
My Honda is having a huge Issue with the O2 sensor, The Code Error are (P0135, P0141). No Mater what i do it wont go away. I'll List the things i have done to fix it.
Had this problem for a month and half. 1.Replace it both down stream and up Stream. 2.Replace the Harness. 3.Check the wire to see if there voltage. 4.Switch ECU to see if it's the ECU- no it's not. 5. Look at the fuse under the Dash, Fuse #15 v7.5. Can anyone help? any advice would help. |
