How cold is your A/C?
mine just had a compressor replaced and it still doesn't quite seem cold enough..
What should the readings be? I can get some gauges. I'm wondering if they didn't replace the O-tube........How could I tell. Where is it in a 99 Honda Civic. I can look to see if there are any greasey hand prints in that area....... |
RE: How cold is your A/C?
You'll get a sense of cooling capacity by measuring the outside temperature and the temperature of the air coming out of the vent. I would think you should see a 25-30 degree temperature difference or more.
and remember on a hot day it could take awhile for the air to get cold... its gotta cool off everything in the tubes. i know mines alittle weak but it still gets cold.... just takes about 10mins for the air to come out cold and about another 10 mins to start to chill ya out to much ;)
I drove over 100 miles and it never froze me out. I had the recirculate on and the a/c button on. dial all the way to the blue. Fan on high. Stays that way and it doesn't get real cold. Just really cool-if that makes sense. |
well if you had the AC part replaced from a shop id take it back to them and tell them the system is not cold enough and have them check the pressure in the system....
You might want to have the shop check whether the refrigerant level is low using manifold gauges and whether the A/C belt is slipping.
ORIGINAL: addiction2bass ... i know mines alittle weak but it still gets cold.... just takes about 10mins for the air to come out cold and about another 10 mins to start to chill ya out to much ;) |
ORIGINAL: addiction2bass well if you had the AC part replaced from a shop id take it back to them and tell them the system is not cold enough and have them check the pressure in the system.... Yes, I know about a/c just don't have guages- but know where to rent them. I'm starting to think they did not replace the expansion valve. if it gets clogged- it won't work as good as it should- Hmmmmmmmmm........ finally on the shop- they called this good............ |
Well, your choices are to return the car for servicing or troubleshoot the problem yourself. The latter requires a set of manifold gauges.
ORIGINAL: RonJ ORIGINAL: addiction2bass ... i know mines alittle weak but it still gets cold.... just takes about 10mins for the air to come out cold and about another 10 mins to start to chill ya out to much ;) ut anyways instead of taking it to the hole in the wall shop take it to a respectable AC shop that can check the system out properly! |
| All times are GMT -8. The time now is 04:55 AM. |
