how to disable ignition key BINGING.......
Old Jul 2, 2006 | 06:52 PM
Default how to disable ignition key BINGING.......
well this is always geting on my nerves!!!!!!!!!!! i park my car in the garage and always leave the keys in it.
how can i disable the BINGING......... i got a new key for my honda and i cannt get it to stop... my old worn out key would get it jsut right and it wouldnt beep.... but they key looks like crap.LOL
Old Jul 2, 2006 | 11:26 PM
AgentofDarkness's Avatar
Default RE: how to disable ignition key BINGING.......
Which binging are you talking about? When does it happen? Like when the door is open and the key is in the ignition or when the key is set of accessory position, etc.
Old Jul 2, 2006 | 11:39 PM
TrAvMaNFTW's Avatar
there should be a little black thing that pushes in here in this pic...
[IMG]local://upfiles/8557/DCF6B75A4ECD48D2856E8121F65D6C73.jpg[/IMG]
Old Jul 3, 2006 | 12:04 AM
In that case, that little black thing is a switch so find the two wires that go into the switch and connect them together. You car will think the door is always closed and the sound will go away.
Old Jul 3, 2006 | 08:54 AM
i dont wanna deactivate the door trigger just the key beeping..........
see i always leave my keys in the ignition so when i get outta the car i just want it not to be beeping.
i realy just need to find that beeping device and either unplug it or wrap it in some deadener so at least its not as loud....
but i would think thier would be a wire on the ignition i could simply cut to deactivate it..... i just dont wanna start cutting and cut the wrong wires
Old Jul 5, 2006 | 10:33 AM
skytanker2003's Avatar
Have you checked the fusebox diagram? There might be one for the Key Alarm (I can't remember)...I think it might be the same one for the Headlight Alarm though. It isn't a big deal though. Once you close your door the alarm stops. And if it's that big of a deal......Just leave your keys in your visor or on the seat...Why do you need them in the ignition all the time?
Old Jul 5, 2006 | 01:30 PM
cause when i wake up to go to work im still asleep.LMFAO
shiaokaz
26
Jul 7, 2008 06:44 PM
shiaokaz
May 27, 2008 09:21 AM
shiaokaz
May 9, 2008 01:13 AM
b3651
Sep 24, 2005 09:46 PM
magnetic blue
Apr 26, 2005 03:49 PM
