how do I torque the upper strut nut?
Old Jan 27, 2009 | 05:39 PM
inthezoneac's Avatar
Default how do I torque the upper strut nut?
on the tip of the strut rod there's an area where you can grip to tighten the nut with an open ended wrench/socket. How do I torque it with a normal torque wrench without spinning the rod and nut together?
Old Jan 27, 2009 | 06:01 PM
you mean the middle strut nut.... i just tightened mine nice and firm with a allen wrench.
its a nice size steel shaft and so far i havent stripped one yet.
but the cheap struts that came on my ground controls coilovers i bought used they were so cheap as hell and no way to hold the strut..... i had to use some vis grips on the shaft between the spring. definatly not good for the strut shaft im sure!
Old Jan 27, 2009 | 06:03 PM
yes middle strut nut, attaches to strut shaft
kyb's use a regular nut and at the very top is a little section that you can hold down/use pliers to grip so you can tighten it. And I do not want to have to grip the shock shaft to torque it down properly.
Old Jan 28, 2009 | 06:22 AM
You could put a torque wrench on the top part and a regular wrench on the center nut. With the strut out of the car, action is equal to reaction. So the torque you measure is the torque of the nut.
tlkolrod
Jul 16, 2010 06:53 PM
gpotski
Nov 27, 2005 08:01 PM
Jeremy102579
Mar 12, 2005 03:07 PM
klamslam
Feb 5, 2005 04:39 PM
silvic00
Jan 12, 2005 11:15 PM
