How do u test a fan switch?
1 Attachment(s)
I have a 95 Civic LX w/ some heating issues. The troubleshooting flowchart in the manual tells me to test continuity btwn terminals on my fan switch. Am I supposed to test continuity btwn 3 terminals? If so...how?
Thanks ______________________________________________ WTB: 1995 Honda Civic LX parts: Fan Switch...if mine is bad (see post) Center panel Projector Headlamps/Taillights PM me |
jump it with a paper clip, google jump fan switch if that doesnt make sense, if you are worried about the switch itself just replace it, they are like $8
Originally Posted by Turtlegrip
(Post 778037)
Also, the lowest I've seen the switch is around $15. I haven't really looked that hard. I've already spent too much this month on the car. I was wondering...since a switch is pretty basic (a device to make a connection), Can I repair it? |
You test one circuit at a time. For example in position 1 there should be continuity between 1 and 4 as well as 1 and 6. (and 4 and 6, but you don't really need to test that).
Typically when the fan doesn't work on high but does on other speeds, the switch is bad (since the position 4 circuit handles more current it is prone to burn out). If the fan works on high but not other speeds the resistor is probably bad. |
Originally Posted by mk378
(Post 778040)
Typically when the fan doesn't work on high but does on other speeds, the switch is bad (since the position 4 circuit handles more current it is prone to burn out). If the fan works on high but not other speeds the resistor is probably bad. That's the way I thought I should do it (test two terminals at a time). OK, so the switch is bad. I wasn't hearing beepis on any combination. That's why I wasn't sure I was doing it right. What do u think about my other question. Can I repair the switch? I was thinking of opening it up & making sure each connection would work as planned. |
Fixed the fan switch. Got continuity like in the manual.
_______________________________________________ WTB: 1995 Civic LX parts: Center panel Aftermarket headlamp/taillight assemblies (projector, halo, something cool?) Center caps PM me |
If they all share one post (wire plug) that one will usually be a common (ground) so like mk said you would just check from there. I just suggested replacement because that is usually a lot easier than trying to repair or worry about a switch, once it is worn it is worn unless you just had a break in a wire. Glad to see you got it working though, bro.
| All times are GMT -8. The time now is 05:32 AM. |
