mk378 |
03-22-2010 05:30 AM |
After doing that, set the spark timing. Find the timing marks on the crank pulley and touch them up with paint or chalk so they're easier to see. There is one single mark, and a group of 3. The group of 3 is used for spark timing. Warm up the engine and install the ECU test jumper like you would to read codes. Start it again and the CEL should come on steady. (If there is a code blinking, resolve it first.) Hook up timing light to spark plug wire #1. Rotate the distributor to fire on the center mark of the group of 3.
