i have no clue
i have a 91 hatch its has a d15b7 with an l-3 trans i went to replace the clutch but when i got the 92-95 clutch it didnt fit i went all the way back to and 88 does anyone have any ideas ? also any one have any clue how toget power outa the motor its soposed to be mutli fuel but the put the duel point fuel ok ? thanks alot in advance
I think you still have a '91 transmission (cable-operated clutch, not hydraulic, right?), so you need the clutch for a '91. The only difference is going to be the throwout bearing arrangement and maybe the input shaft of the transmission.
The DPFI system doesn't have high performance but it is rather easily replaced to a 92-95 style MPFI. That would be the first thing to consider to increase performance.
yes you should be able to put the flywheel from the 91 on the b7 block. http://hondaswap.com/swap-articles/d...writeup-49557/. that should help you a little on the mpfi swap
flipperlazo
May 6, 2008 10:56 AM
SiX
Jun 7, 2007 05:43 AM
jbarham
Apr 4, 2006 03:05 AM
jaymacf3
Jan 20, 2006 10:45 AM
