I need help 95 civic won't start
Old Mar 2, 2012 | 11:52 AM
Mecca8383's Avatar
I agree with MK, it's easy to mess up the plugs on the distributor if you don't "READ" a manual such as the Honda Manual or at least a Haynes book.
But it also could be the Plugs themselves as well if they'll too old.
Old Mar 2, 2012 | 12:31 PM
DietrichB1's Avatar
Is the firing order 1-3-2-4? Starting from
The bottom? And how do I know if its making spark at all? I remember it was hard unplugging the wires from the distributor and I pulled it from the wires instead of pulling from the plastic. Could I have damaged The wires?
Old Mar 2, 2012 | 12:51 PM
DietrichB1's Avatar
So if I messed up the wire harness, cause I did tug on them, how would I repair that?
Old Mar 2, 2012 | 01:09 PM
droopy128's Avatar
I believe it 1-3-4-2.. count clock wise starting from bottom left..
You may have flip flop the 4 & 2.. try that..
Old Mar 2, 2012 | 05:34 PM
Pull out the spark plug end of one of the wires and put a spare plug into it. Hold the shell of the plug against the engine, crank, and observe if the plug sparks (with a bright white spark). Repeat with the other wires.
Cylinder #1 is of course the one furthest from the distributor. I think post #1 is at 7 o'clock but it could be 10 o'clock. There is usually a mark on the cap for #1. You could try moving all the wires one place clockwise and try again.
For anyone reading this in the future, realize that the o-ring can be replaced without unplugging anything.
Old Mar 3, 2012 | 05:34 PM
DietrichB1's Avatar
okay so i tok of the wire that goes on top of number 1 spark plug and i cranked the car but i didnt see a spark at all, is this why my engine isnt turning over?
Old Mar 3, 2012 | 10:05 PM
DietrichB1's Avatar
i tried 1-3-4-2 and nothing so i replaced the rotor, and there is still no spark on the plugs, my guess the last thing it can be is the coil?
Old Mar 4, 2012 | 03:06 AM
Or the low voltage wires from the harness to the distributor are broken. Check the ECU for any distributor sensor codes. Check that the coil is getting battery voltage on the low voltage terminals (you will need to remove rotor and separator plate).
dqcivic
Jul 29, 2010 03:56 PM
free_2_one
Feb 1, 2008 05:31 PM
boyye
Oct 17, 2006 02:42 PM
me262dave
Jul 17, 2006 05:13 PM
shannon1977
Nov 23, 2005 08:34 AM
