I think I blew a fuse..?
Old Jan 27, 2008 | 06:44 PM
Vilex's Avatar
Default I think I blew a fuse..?
Well, I was trying to get my Dome Light cover off, and i was trying to do it a little too fast ( I was in a hurry to get to work), and I was using a flathead screwdriver, and I got it off and went through and touched the domelight bulb a little bit I think, and it turned on then turned off. Now the domelight doesn't work when I turn it on, or my maplights won't turn on. I think I could of possibly grounded it, or blew the fuse by having the screwdriver touch the bulb? The car was off when I was doing this also.
I'll check my fuse panel tommorow probably, and see if I blew the fuse, I just wanted to make sure it was a blown fuse, and wanted to run it across everyone before I checked . I'm going to put in a 16 Superflux Domelight from Oznium soon, and I had to measure my domelight. On a 01 Civic, its kinda.. Not-so-roomy.. I'll be lucky if I can get the domelight to fit. Its 1.5"x1.5" and one side is about 1.3" and the width wise its about 1.8" or something like that. So lets hope I can make it fit, lol.
Old Jan 27, 2008 | 06:59 PM
Default RE: I think I blew a fuse..?
Yes probably the fuse, since the map lights don't work either now. Once you know which fuse it is, pull the fuse out next time you're working on it. It doesn't matter if the car is on or not, this circuit is always live.
It's also pretty easy to blow out a bulb by bumping it while it's lit.
stuck in san diego
Apr 25, 2013 08:19 AM
iaaz
Oct 27, 2010 04:17 PM
croninc
Apr 29, 2009 03:05 PM
redblur07
EK Swaps
May 1, 2008 02:28 PM
curlybandit
Jan 7, 2007 01:40 AM
