HondaCivicForum.com
-   -   idle jitters (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/idle-jitters-30237/)
sccatadriver Oct 5, 2006 05:30 AM
idle jitters
I have a 97 Civic DX coupe. After the enginge warms up, at idle, it wants to run kinda rough. It just started recently. Going through the gears, it seems to run just fine. Can anyone point me in the right direction as to what might be going on.
fglaustin Oct 5, 2006 10:34 PM
RE: idle jitters
how many miles since the last tune-up.
no codes ??
could be plug wire, pcv valve, air filter.
sccatadriver Oct 6, 2006 05:35 AM
RE: idle jitters
I just bought the car recently with 150,000 miles on it. Tune up? Not sure about. Air filter? New air filter. As far as a pcv valve, I don't think my model has one. I've looked all over for the pcv, if there is one can you tell me where it's located. The car has thrown no codes as of yet.
fglaustin Oct 6, 2006 05:31 PM
RE: idle jitters
open up the hood after dark and start the car.
see if there are any sparks flying - bad spark plug wires may show up.
if you do not see any sparks, i would still do a tune-up since it is unknown when it was last done.
plugs, rotor and cap.
i pretty sure you have a pcv valve.
what engine:
4 Cylinder Engines
4 Cylinders 01590 1.6L MFI
4 Cylinders 01590 1.6L MFI VTEC-E
rit14623 Oct 9, 2006 11:39 AM
RE: idle jitters
ORIGINAL: sccatadriver
I just bought the car recently with 150,000 miles on it. Tune up? Not sure about. Air filter? New air filter. As far as a pcv valve, I don't think my has one. I've looked all over for the pcv, if there is one can you tell me where it's located. The car has thrown no codes as of yet.
I just replaced my pcv valve, 95 Civic LX, D15B7 engine
There is a hose that goes from the intake manifold to the valve cover. The hose is about 1 cm wide.
On the top, backside of the valve cover, there is an L-shaped plastic tube that sticks up and then into that tube. It's a bit difficult to pull out because it's under the fuel rail and injectors and intake manifold, but I used a wrench, which ruined the old one. Anyway, it is between the two fuel injectors on the right hand side of the engine.
If you buy a new PCV valve, you can see what it looks like and then you can scan the top of the valve cover to find the matching part.
alpine06 Oct 10, 2006 07:37 PM
RE: idle jitters
i'm having the same problem. i have a 2000 civic ex JRSC. runs beautifully except during idle its real shaky and the rpms just die untill it revs itself when it gets low.
burtonripply Oct 11, 2006 02:41 AM
RE: idle jitters
i suggest seafoam... http://www.seafoamsales.com/motorTuneUpTechGas.htm
think u said ur cars at 150, 000kms so there is maybe build up of carbon ect. on valves/injectors which would give a rough idle. but then when your going through the gears your working your engine more so the carbon buildup doesnt have as big of an effect. just my thoughts.,.... anyone second that?
alpine06 Oct 11, 2006 03:01 AM
RE: idle jitters
I actually used seafoam a while back, didn't help the idle shaking much.
jbum Oct 14, 2006 01:29 PM
RE: idle jitters
a couple of things you can look into... dirty throttle body and idle air control valve (IACV/EACV). Try the other suggestions as well.
Mad7s Oct 14, 2006 05:25 PM
RE: idle jitters
Spark plug gap and perhaps cleaning. Easy check and fix if it's the problem.
