InNeed Of Some HelP
Old Sep 3, 2009 | 06:31 PM
alexfos101's Avatar
Default InNeed Of Some HelP
Hello to all honda owners i need some help with my car i have a 99-00 honda civic ek3 sedan d15z4 non v-tec i want to do some modification to it but i dont know where to start, it's bone stock an originally 5 speed manual runs good but ill like it to be a little faster with the acceleration what can i do??? ps i dont want to swap the engine i like my engine just want it to be a little more peppy!!
Old Sep 3, 2009 | 06:34 PM
D15Z4
  • Found in:
    • 1996-2000 Civic Exi and SA Ballade & Civic 150i
      • Displacement : 1,493 cc (91.1 cu in)
      • Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.3 in)
      • Power : 90 hp (67.1 kW, 91.3 ps) or 105 hp @ 5800 rpm
      • Torque : 99-103 ft·lbf (14 kg/m, 134-140 Nm) @ 4200 rpm
      • Valvetrain : SOHC (4 valves per cylinder)
well if you dont want to do any motor swaps....how much are you wanting to spend and how much more hp do you want?
Old Sep 6, 2009 | 08:09 PM
alexfos101's Avatar
Thanks for the reply '94civic" ,,money is no issue im looking to get around 60 to 80 more bhp..
Old Sep 6, 2009 | 09:06 PM
i suggest building the engine and putting a turbo on it. then get it tuned.
Old Sep 7, 2009 | 06:48 AM
sandrider123's Avatar
that much of a power leap your probably going to be better off swapping to a GSR or JDM B16 I would suggest the GSR for the torque
Old Sep 7, 2009 | 08:04 PM
alexfos101's Avatar
Thanks for all the info..Just two question when turbo chargin do on the engine would i still b able to use the ac.... and is there a tuned ecu for my engine (d15z4) non vtec
Old Sep 7, 2009 | 08:33 PM
yes they sell turbo kit's that allow you to keep your a/c. it's best to find a local shop that tunes ecu's. chrome is a good tune for a ecu
Old Sep 8, 2009 | 06:17 PM
alexfos101's Avatar
what u think bout cam shaft does it make a difference in the peformance
Old Sep 8, 2009 | 06:21 PM
a little bit. it opens our valves more to allow more air/fuel in and it also allows you to rev farther. i think you should do some research on building your engine for turbo.
Old Sep 13, 2009 | 01:00 PM
alexfos101's Avatar
thanks. which will be the best performance cam for my engine and which stages
