Installed stereo now airbag light on???????
Old Sep 6, 2006 | 05:19 PM
Scroder's Avatar
Default Installed stereo now airbag light on???????
Ive installed a ton of decks, but now after installing my new deck in my 2004 Civic, the airbag light is on. Can anyone think of something in the installation of a deck that would cause this? Should I disconnect the negative battery cable to see if it clears it? Thanks,
Dave
Old Sep 6, 2006 | 05:32 PM
windcalmer's Avatar
Default RE: Installed stereo now airbag light on???????
SEARCH BUTTON...Its a good thing. There are many many many posts about this very thing. I am not trying to be rude, please dont think that. But if you do a search you find your answer.
Just so you dont think im being an @$$ here are just a few off the top ten countdown.
https://www.hondacivicforum.com/m_133604/tm.htm
https://www.hondacivicforum.com/m_99522/tm.htm
https://www.hondacivicforum.com/m_168386/tm.htm
Have a good one and good luck. My SRS light has been on for a year.
Old Sep 6, 2006 | 08:14 PM
Scroder's Avatar
Does this mean its a faulty light and it still works or what? The links didnt provide info as to if there are problems with the airbag systems or something else going
Dave
Old Sep 6, 2006 | 09:09 PM
windcalmer's Avatar
O.K. If your SRS light is on (at least on the EK civics 98-00) it means that there is a trouble code stored in the system and when there is a code stored in the system the air bags are disabled. Meaning they will not work if you hit something really hard. Go to the dealership inyour area and have them pull the SRS codes. They will be able to reset the system there. It will however cost you around $80. There have been a few writeups about resetting the system yourself, but i could not get them to work. Good Luck.
Old Sep 7, 2006 | 02:26 AM
Scroder's Avatar
I have a OBDII reader but was unable to reset the SRS light since its not a check engine light---the car is under warranty do you think this would be covered? Thanks
Dave
Old Sep 7, 2006 | 02:49 AM
if its under warranty it should be covered. try checking your dealer and see what they say good luck. oh by any chance did you take your seats out? check this thread https://www.hondacivicforum.com/m_245987/tm.htm
Rool_908
Jan 3, 2012 07:03 AM
blatin
Jun 3, 2007 12:31 AM
hciv
Oct 24, 2006 07:01 PM
mentaldis0rder
Jun 27, 2006 06:22 PM
SIG
May 10, 2005 12:33 AM
