Interior hood release
Old Apr 9, 2008 | 10:10 AM
masiu's Avatar
Default Interior hood release
Well....I pulled the hood relase in the cabin and broke it. Broke the square tab right at the round joint. Its a 99 civic hatchback DX. I can still see the round stem sticking out and if I grab hard enough I can luckily still pull on the cableto open the hood.
Now....can I just get a new or used handle (plastic part) and screw it back in...or is there a lot more work involved?
......thanks guys!
Old Apr 9, 2008 | 10:38 AM
mxs's Avatar
mxs
Default RE: Interior hood release
You have to replace the entire cable. I just did it on the CRX, it wasn't THAT bad. The part is cheap, under 20 bucks I think. Had to pull the fenderliner and front bumper.
Old Apr 9, 2008 | 11:05 AM
masiu's Avatar
thanks MSX.............I'm fairly handy at fixing most things...however I've never really tried to take a bumper off. Is it fairly straight forward on the 99 civic and do I have to deal with any of the airbag sensors?
M
Old Apr 9, 2008 | 11:36 AM
mxs's Avatar
mxs
No, it's really straightforward. A bunch of plastic clips above the grille, and some screws inside the wheel well, maybe a couple fasteners under the front of the bumper too.
Old Apr 13, 2008 | 03:57 AM
Hobo's Avatar
Apparently this is a common problem. Mine broke in the same place on my 97 Civic.
Dealer wants $180 to replace the cable.
I've been using vice grips to pull the cable.
Old Apr 13, 2008 | 07:44 PM
asdfbrendan's Avatar
^ +1...I've been doing the same thing. I can get it w/ my fingers about 50% of the time, otherwise I've gotta bust out the pliers.
Old Apr 16, 2008 | 08:52 AM
masiu's Avatar
Just looking thru the net and found other info......
apparently there was a TSB (Technical Service Bulletin ) issued on this problem and Honda is aware of it. It is TSB 99-089...title "Hood Release Handle Breaks".....
the question is....will Honda repair this thru goodwill....?
Old Apr 16, 2008 | 09:01 AM
mxs's Avatar
mxs
ORIGINAL: masiu
I doubt it. It wasn't a recall, and your car is almost 10 years old now. Spend the money on the part and just fix it yourself
Hobo
Feb 16, 2008 10:18 PM
mytimetogo
Jan 22, 2008 11:31 AM
mybrokenblinker
Dec 5, 2006 08:55 AM
redlines4us
Aug 22, 2006 05:49 AM
Littleneckhalfshell
Feb 24, 2005 03:24 PM
