Intermitent starting
Old Jan 22, 2007 | 12:31 AM
rr2's Avatar
rr2
Default Intermitent starting
I have a 93 1.5l that was running fine, then shut it off one day and it does not want to restart. All engine lights turn on when ignition is turned on, but fuel pump does not run. Turning the ignition from the off postion to the on position eventually will get the fuel pump on. Then the car will run fine until the next time it's turned off. No codes are stored in ecu. Replaced the main relay, coil, and ignitor and still have same problem. Map sensor is in speck for voltage, ground wires at thermostat housing clean. Sometimes the gear selector lock will pulsate off then on quickly. Is there a way to check the ecu? Could this be a faulty ground? Any ideas would be greatly appreciated!
Old Jan 22, 2007 | 10:26 AM
theredsuit's Avatar
Default RE: Intermitent starting
I was going to mention Main Relay before I finished readingyour post. You should check the voltages at the fuel pump. You may have some short in the wiring.
Old Jan 22, 2007 | 11:01 AM
rr2's Avatar
rr2
Fuel pump has voltage and when #5 and #7 wires are jumpered at main relay, fuel pump will run with pressure in speck.
Old Jan 22, 2007 | 02:53 PM
civic2001's Avatar
I had a 90 Accord that had a "fuel pump" relay that would work intermittently. It would almost never pull in when the sun beat down on the dash because it was located to the left of the steering column way up under the dash.
e_rock
Oct 3, 2008 07:06 AM
kbeezy13
Mar 1, 2008 06:39 AM
totenkopf
May 31, 2007 03:36 PM
cbrandes
Feb 15, 2007 01:00 PM
raphn
Jun 14, 2004 02:07 PM
