Knocked out light on automatic shift console (2004, 4 door)
Anyone know how I can fix it? The little light that illuminates the center console shifting panel has been knocked out. I recently took off the trim pieces and pulled out the center console in order to install an aux jack to the back of the factory stereo and when I put it all back together the light that had always turned on no longer did. I took apart the shift trim and the light is still there but it no longer will go on. The wires all still look to be connected but nothing is happening.
Anyone have any ideas as to how I can try to fix this? |
check the wires for juice when your headlights are turned on. if you have power through them then its the bulb
