HondaCivicForum.com
-   -   location of engine block coolant drain bolt??? (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/location-engine-block-coolant-drain-bolt-83938/)
soundquest Jul 6, 2010 11:02 PM
I am in the process of draining the coolant on my 99 Honda Civic LX SOHC 1.6L. Does anyone know where the drain bolt is on the block (if there is one)?
Thanks.
civicalized Jul 6, 2010 11:35 PM
seek the answer
find the answer in a genuine honda repair manual
mk378 Jul 7, 2010 02:34 AM
It's on the exhaust side (front as the engine sits installed in the car) of the block near the transmission end. It's a large round plug the whole thing unscrews.
RonJ Jul 7, 2010 05:27 AM
1 Attachment(s)
Attachment 10687
mk378 Jul 7, 2010 06:14 AM
OK so it's in a different place than the D15. Learn something about Civics every day...
RonJ Jul 7, 2010 09:32 AM
^And yet is still the best Civic tech on the internet, bar none.
soundquest Jul 7, 2010 10:32 AM
You guys are awesome, thanks so much.
Emory Jul 27, 2021 08:23 AM
Coolant drain plug
PCV valve plate is leaking coolant from behind it is the drain plug located behind the PCV valve plate on the back of the motor 2001 Honda Civic ex
if not how could coolant get inside behind the PCV valve plate is anything behind that plate
