Low idle and jerky low RPM acceleration
Old Aug 23, 2008 | 12:39 PM
boostphreak's Avatar
Default Low idle and jerky low RPM acceleration
My idle has been really low (since I bought the car) although it has never died, I've felt it get low enough to where I thought it was going to die. With the A/C on, it idles where it normally should. The idle adjustment screw has never been touched so I'm thinking it's related to the jerky acceleration I'm having.
The problems are:
Lower idle than normal...i think?
Jerky low RPM acceleration until after 4,000RPM top end hauls butt.
The problem is worse if I push the gas pedal too much at lower RPMS but if I just barely give it gas, I don't feel it.
So far I've checked and adjusted the timing and replaced spark plugs, fuel filter and made sure the cat. wasn't clogged.
Old Aug 24, 2008 | 08:55 AM
Jorge.s's Avatar
Probably the problem is in the fuel delivery;fuel filter, fuel pump etc. Check the fuel pressure it would give you a idea.
Old Aug 24, 2008 | 06:35 PM
The fuel filter is new but my fuel pump sock might be dirty I guess or the pump could be going out. The spark plugs looked the same but they were rather white and not the perfect tan color I like to see.
Old Aug 24, 2008 | 07:15 PM
What year Civic?
Is the CEL ON?
Did you jump the service connector and use a timing gun to check the ignition timing?
Have you tried cleaning the IACV (see forum DIY)?
Old Aug 25, 2008 | 12:35 AM
Originally Posted by RonJ
What year Civic?
Is the CEL ON?
It's a 2000 EX 5spd.
The CEL is on but the code is P1457
I did jump the service connector.
I'll clean the IACV next.
Old Aug 25, 2008 | 04:53 AM
Have you retrieved CEL codes since the problem started?
Old Aug 26, 2008 | 12:41 AM
The problem has always been there since I bought the car but I have checked codes 3 times and always checked out the be 1457. I still need to fix that too but I don't think it would hurt performance... just prevent me from getting an inspection?
Old Aug 26, 2008 | 03:10 AM
GReddy_Civic's Avatar
Snail'n Admin
heres a few other things that MAY be it. Theyre a fairly cheap fix so id start with them, if in fact it is not the CEL. Change the spark plugs/plug wires, dizzy cap/rotor, fuel filter, check the IACV (like RonJ said, its in the DIY section (i wrote it)) and the Fast idle valve
Old Aug 26, 2008 | 05:24 AM
Code P1457 is indicating a problem with the evaporative emission control system. Start by checking whether the seal on the gas cap is bad.
GReddy_Civic has some good tips; however, the 2000 Civic doesn't have a fast idle valve.
Old Aug 27, 2008 | 12:10 AM
I've read that a bad gas cap doesn't show a 1457 code?
