HondaCivicForum.com
-   -   Low idle and jerky low RPM acceleration (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/low-idle-jerky-low-rpm-acceleration-69212/)
boostphreak Aug 23, 2008 12:39 PM
My idle has been really low (since I bought the car) although it has never died, I've felt it get low enough to where I thought it was going to die. With the A/C on, it idles where it normally should. The idle adjustment screw has never been touched so I'm thinking it's related to the jerky acceleration I'm having.
The problems are:
Lower idle than normal...i think?
Jerky low RPM acceleration until after 4,000RPM top end hauls butt.
The problem is worse if I push the gas pedal too much at lower RPMS but if I just barely give it gas, I don't feel it.
So far I've checked and adjusted the timing and replaced spark plugs, fuel filter and made sure the cat. wasn't clogged.
Jorge.s Aug 24, 2008 08:55 AM
Probably the problem is in the fuel delivery;fuel filter, fuel pump etc. Check the fuel pressure it would give you a idea.
boostphreak Aug 24, 2008 06:35 PM
The fuel filter is new but my fuel pump sock might be dirty I guess or the pump could be going out. The spark plugs looked the same but they were rather white and not the perfect tan color I like to see.
RonJ Aug 24, 2008 07:15 PM
What year Civic?
Is the CEL ON?
Did you jump the service connector and use a timing gun to check the ignition timing?
Have you tried cleaning the IACV (see forum DIY)?
boostphreak Aug 25, 2008 12:35 AM
Originally Posted by RonJ (Post 584828)
What year Civic?
Is the CEL ON?
It's a 2000 EX 5spd.
The CEL is on but the code is P1457
I did jump the service connector.
I'll clean the IACV next.
RonJ Aug 25, 2008 04:53 AM
Have you retrieved CEL codes since the problem started?
boostphreak Aug 26, 2008 12:41 AM
The problem has always been there since I bought the car but I have checked codes 3 times and always checked out the be 1457. I still need to fix that too but I don't think it would hurt performance... just prevent me from getting an inspection?
GReddy_Civic Aug 26, 2008 03:10 AM
heres a few other things that MAY be it. Theyre a fairly cheap fix so id start with them, if in fact it is not the CEL. Change the spark plugs/plug wires, dizzy cap/rotor, fuel filter, check the IACV (like RonJ said, its in the DIY section (i wrote it)) and the Fast idle valve
RonJ Aug 26, 2008 05:24 AM
Code P1457 is indicating a problem with the evaporative emission control system. Start by checking whether the seal on the gas cap is bad.
GReddy_Civic has some good tips; however, the 2000 Civic doesn't have a fast idle valve.
boostphreak Aug 27, 2008 12:10 AM
I've read that a bad gas cap doesn't show a 1457 code?
