Manual Door Lock Won't Unlock
Old Jul 29, 2005 | 01:57 PM
tamda00's Avatar
Default Manual Door Lock Won't Unlock
Hi All,
I am a newbie to this forum. I need some help and advice from you guys.
I drive a 2000 Civic hatchback. The passenger door will not unlock. I can put the key in but it will not turn.
I tried unlocking it from the inside but the switch will not turn either. This happened after I parked the car for 2 months. Before that I had a hard time locking and unlocking. Now it won't turn at all.
Thanks
Old Jul 29, 2005 | 09:01 PM
bleedhondos's Avatar
Default RE: Manual Door Lock Won't Unlock
is your lock power operated? If that maybe the case the wires could be mess up or basiclly your lock is broken. You can open your dor panal to take a look at it.
Old Jul 30, 2005 | 12:02 AM
LEVIII's Avatar
I dont belive they offered the hb in power options.
You will need to take your door panel off and check out the lock and unlock rods going to the lock. SOunds like one is bent or ruseted up good.
Old Jul 30, 2005 | 03:09 AM
Mad7s's Avatar
Agreed. Check those first. I had the same problem in my 88 hatch when I switched out door handles. Also, if they're not bent or rusted, fiddle with the distance the handle is from out door handle. That was my issue. Man, I really just typed fiddle.
Old Jul 30, 2005 | 09:47 AM
ngoti 8tor's Avatar
[sm=welcomesign.gif] to HCF. [sm=groupwave.gif][sm=groupwave.gif][sm=groupwave.gif]
Old Jul 30, 2005 | 10:00 AM
LEVIII's Avatar
Do you have aftermarket door lock actuators in there?
Old Jul 30, 2005 | 10:57 PM
tamda00's Avatar
ORIGINAL: LEVIII
Thanks for your responses fellas! My car doesn't have power door lock so there are no actuators. It's just the reg honda door lock.
I guess I will have to take the door panel off inorder to find out what the cause is.
Old Jul 30, 2005 | 11:49 PM
StifflersMom's Avatar
Cat Fuсker
take the pass seat out too as it'll make ur life easier
Old Jul 31, 2005 | 01:52 AM
LEVIII's Avatar
ORIGINAL: Kolhoznik
huh?
Tinkerbell_too
Jan 17, 2009 10:56 AM
sfazngiants
Feb 29, 2008 12:08 AM
Koala
Oct 12, 2007 09:38 PM
Faithbleed
Oct 22, 2006 05:51 PM
deeg
Jul 25, 2006 07:00 PM
