manual window replacement
Old Mar 14, 2012 | 08:30 AM
98hatchem's Avatar
Default manual window replacement
ive got a 98 dx hatch.
driverside window, is broken- you can slide the window up and down by grabbing the glass from the inside and outside and pushing down. Ive taken the door panel off to investigate and see what i can do about replacing the parts whenever i find a decent donor from a junkyard. basically the gear inside the door is stripped because the handle doesnt move when the window moves.
From what i see there are a number(cant remember off hand how many there were) of bolts(looked like 12mm) that i can take off. Now my question is do i have to remove the window also when i do this?
Is there a write up, for this procedure that i havent seen?
Any help would be great, since the car is very vulnerable to thieves this way.
Old Mar 14, 2012 | 02:40 PM
You need to replace the window regulator. I suggest a new one rather than from a junkyard because on the driver's side, a used one may be about worn out too.
The regulator attaches to the bottom of the window with 2 bolts. You don't have to remove the window from the car but it will be completely loose so be careful not to let it drop and break.
Rattlin_Steele
Jun 6, 2011 10:45 AM
AGibney
Dec 29, 2009 05:59 PM
Rusty Shackleford
Jul 26, 2009 11:09 AM
burnindesirez02
Sep 8, 2008 05:01 PM
