which master cylinder do i get?
Old Feb 7, 2008 | 07:40 AM
ic892003's Avatar
Default which master cylinder do i get?
i need a new clutch master cylinder, im going to buy a generic one online, therep retty cheap they range from $40 to $70, but does it matter which brand i get, i mean im not going to the dealership cause they charge an arm and a leg.... would any one of these be ok and which one do u guys think is the best for the price
http://www2.partstrain.com/store/?N=...967+11921+5561
Old Feb 7, 2008 | 07:50 AM
ic892003's Avatar
Default RE: which master cylinder do i get?
or even something like this??
http://cgi.ebay.com/ebaymotors/1992-...em150213157241
Old Feb 7, 2008 | 12:17 PM
no idea. but i know i have to buy one myself preaty soon. OEM price is about 140bucks. i havent priced autozone yet.
Old Feb 7, 2008 | 12:26 PM
ic892003's Avatar
damnn addiction, we gotta get these frickin cylinders fixed lol
Old Feb 7, 2008 | 01:20 PM
ya mines leaking on the inside of the car slightly... not to bad.....
ive thought about buying new OEM. but i think i might just cheap out on one. its a preaty minor part that just needs to not leak for me.
Old Feb 7, 2008 | 06:08 PM
EJ8_Man's Avatar
Both my Civics leak a little hydraulic fluid. I think it's normal for them to do that. As long as its a very light leak. If you think about it, it kinda makes sense too. The plunger rod is getting immersed in hydraulic fluid and then pulled back out again. Over and over and over and.... So even if a very fine layer of hydraulic fluid is still on the rod its going to build up over time and look like a leak. Wipe it clean and see if its leaking without pressing the peddal. If it is then it might be cheaper to rebuild the cylinder by buying the rubber gaskets and seals for it.
Old Feb 7, 2008 | 06:17 PM
well its definatly not NORMAL.LOL
think about it your brake pedal doesnt leak fluid does it? i know mine sure dont.......
needs to be replaced. if fluid can leak out then air/ moisture can also get in.
Old Feb 7, 2008 | 06:26 PM
EJ8_Man's Avatar
Ya never thought of that, and then the fluid oxidizes in the lines, and you could get air in the lines. Changing the seals should be pretty cheap if you can find a kit. Honda will probably charge $20-30. I've seen kits for motorcycles, but not civics... Still looking.
Old Feb 8, 2008 | 04:58 AM
JimBlake's Avatar
When I needed a brake master for my Integra, I looked & never had any luck finding a rebuild kit.
OTOH, one common reason for the MC to fail like that is corrosion/pittingon the bore of the MC body. New seals aren't gonna fix that.
Old Feb 8, 2008 | 06:15 AM
gwl's Avatar
gwl
I got the ones from Ebay - Grip Force. I replaced both master and slave cylinder even only the master was leaking. I think the total price for both pieces was around 60 bucks.
