mini me questions
k thats what i thought i have the d15b7 and i am looking for the head off a d16z6 and the ecu out of it, and wire up the vtec then i have a td04 turbo and going to run just like 5 or 6 pounds of boost, see how she holds haha
hey i did a swap d15 to a d16 vtek but after driving 2 weeks im getting conpreccion inside my colant water someone told me to change the termostat i did now geting white smoke out tailpipe wat can i do please help
If you do a mini me swap and then you boost it you gonna have a big problem, because what you do when you swap a vtec head on a non vtec block you rise your compression ratio and if you use a turbo on this set up your block wont hold the punishment no to mention the other components, like pistons and rods, chinobk, take the cylinder head to the machine shop resurface it get a new head gasket and when you install it again retorque the head bolts to 70 pounds per foot, not 49 as the manual says, trust me I did it in my swap and fix the problem.
khanselman
Aug 25, 2006 12:40 PM
campbuds
Jul 20, 2006 02:16 PM
