Is this minime possible?
I have a chance to buy a motor off of a 91 teg ls, i believe its got a b18, im not sure if its a a1/a2. Im thinking about the whole motor swap into my 91 hb, but i have a sohc zc in it now. and i have no idea about that swap. but i was wondering if i can do a minime swap. put the head from the 1.8 on to my zc. has it been done? or am venturing off into the wilderness. any comments will help.
Thanks,
Mike
Thanks,
Mike
Like those guys said, no, you can't put that head on your motor, but you can swap the whole motor and tranny into your hatch and then put a B18 or a B16 vtec head on the LS motor. That's called a Frankenstein, and it's quite a bit more potent than it's little brother the mini-me.
No, the LS mounts were made to fit the Integra engine bay. You'll need custom mounts, preferrably ones that drop the engine slightly so you don't have to "modify" the hood or remove the upper timing cover to clear the cam gears.
civic96dxcp
Sep 2, 2005 05:50 PM
