HondaCivicForum.com
-   -   minime swap issue (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/minime-swap-issue-64580/)
VK Apr 27, 2008 03:29 AM
minime swap issue
hello there,
I`ve done a minime swap (d15b7block+d16z6head), also changed exhaust manifold to 421, ecu p28. CR=10.9, but my dyno shows only 113hp. vtec engages, no check engine light, everything looks normal. here my dyno results (sorry for bad quality)
http://img118.imageshack.us/my.php?image=spa0378br5.jpg
any ideas what could be wrong? thanks.
addiction2bass Apr 27, 2008 04:45 AM
RE: minime swap issue
looks fine to me... power jumps at about 4.5K rpms.
remember your geting the power from the tires.....
Fiirkan Apr 27, 2008 04:46 AM
it's 129 to the crank for a Z6 so 113 sounds about right for that mini me setup
addiction2bass Apr 27, 2008 05:29 AM
should have done a BEFORE dyno run ;)
VK Apr 27, 2008 12:07 PM
damn.. my d15b7 to the wheels on dyno 100hp, i think b7 with CR of 10.9 would have +10hp...
i leftintake manifold fromb7,couldz6 manifold add something? hmmm.... I`ll try wideband to check air-fuel...and then maybe leakdown test.. becouse have no idea.. those 113hp ar not enouth.. heremy friends minime swap dyno looks mutch better http://img329.imageshack.us/my.php?i...anodynoaw7.jpg
