misfire after full exhaust install
Old Aug 7, 2014 | 07:05 AM
grove's Avatar
Default misfire after full exhaust install
98 civic ex 5 spd. put a full exhaust system on it, one for ebay because of $$$ issues and because my stock manifold was cracked and my intermediate pipe had holes. after install the car now misfires, no codes are thrown about a misfire. its intermittent. gas mileage is also suffering from it to obviously. i do have 1 code that pops up since the install and its 1325 which is knock sensor. any ideas to why a full exhaust change would cause a knock sensor code and miss fire? again they are random the both of them. but both began when new exhaust was installed.
Old Aug 7, 2014 | 01:32 PM
brettv707's Avatar
sounds like an oxygen sensor problem, dont know why its not throwing codes tho..
Old Aug 8, 2014 | 05:22 AM
grove's Avatar
both o2 sensors are new.
Old Aug 9, 2014 | 03:16 PM
itburnswhenIP's Avatar
maybe you have an exhaust leak ebay products aren't exactly known for there craftsmanship especially there donut gaskits.
Old Aug 10, 2014 | 05:38 AM
Have you reset the ECU since installing the exhaust. I would reset it and see if the codes come back. How old is your ignition system? (cap, rotor, plugs, wires)
Old Aug 17, 2014 | 06:54 AM
grove's Avatar
ive reset the ecu many times. the cap, rotor, distibutor, wires and plugs are all less than a year old. i have no exhaust leaks. im really at a loss of what is wrong with this car. the misfire is interemittent, gas mileage sucks, idle quality sucks. all this started after the new exhaust. could all this be related the fact the cat, is one of those supposedly "high flow" cats. but when you look through there isnt nothing in there. the exhaust shop told me without a cat there, the car could run to rich. but that might be on newer cars he thought.
Old Aug 17, 2014 | 10:28 AM
It does work better with some back pressure. An empty cat means you're polluting unnecessarily as well.
You should also check the valve adjustment because if they are too tight it will cause misfiring especially at idle.
bojadada
May 12, 2014 08:43 PM
MaximusFunk
Apr 10, 2011 08:18 AM
FRESH96
Dec 12, 2007 09:18 AM
2006HondaCivic
Feb 21, 2006 10:15 AM
