need help with distributor
Use a permanent marker to draw a line across the lug on the distributor and the head where the top bolt is. Then put it back on in the same position so the line lines up. Note that it is possible to engage the shaft so the rotor is 180 degrees out of phase. This won't damage anything, but the engine won't start. So you should note where the rotor points before removal. Of course then don't turn the engine while the distributor is off.
dberg1363
Apr 23, 2011 10:43 PM
xiongskies
Feb 22, 2007 04:36 PM
rodbuster
Jan 26, 2006 06:51 AM
mONgS2you
Mar 16, 2005 10:59 PM
