Need help fixing drivers door window regulator
When I roll up my power window(driver's side) it goes up all the way and down all the way. Problem is when it goes to the very top something skips or gets loose and the window drops down about 1/6" inch. I can roll it back up and it'll do the same thing. It only happens when it reaches the very top.
So I just need to know how to get to the regulator, if it's not too hard to tighten up the brackets that attach to the window, which I'm assuming is loose. If any of you have had this problem please let me know what is wrong and what needs to be fixed. I'd rather try to do it myself than spend money at some place to overcharge me to fix it.
to get to the regulator just take off the door panel
and there should be about 10mm bolts 8 i think..
but roll your window down until you can see the 2 bolts for the window 1 on each side and take out the window first..
then take out the regulator and just look if everything is in check...
ORIGINAL: inthezoneac
where can I find that plastic water shield on the inside and what do I use to reseal it?
97Ej8
Apr 24, 2012 04:56 PM
Rattlin_Steele
Jun 6, 2011 10:45 AM
addiction2bass
Feb 21, 2007 05:49 PM
