HondaCivicForum.com
-   -   need help with mini me (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/need-help-mini-me-37775/)
boriquno97 Feb 9, 2007 04:04 PM
First let me start with what i have.
Ihave a 97 civic dx coupe with manual transmission. The partsI have for my mini me project are: d16y8 head, head gasket, timing belt, intake manifold, fuel rail, injectors,throttle body, and an ecu for a 97 civic ex MT.I researched and i understand how to put on the head, torque spec etc.. but whereI am confused at is when using the p2p ecu you have to install a knock sensor(where will this go?) Also fromwhatI understand the ecu will hook up without havingto do any rewiring. This is my first time working on a honda motor,I have worked on engines before but most of my experience is with working with a diesel engines.I would appreciate any help on this matter.
Thanks
