new honda guy needs help
yes they are right and thats what i thought too but i have checked that too.....i just dont get what the problem could be i have a new fuel pump and filter, new plugs gapped right, the timing is right getting the right power to the injectors,the ingnition timing is right and im getting spark
Congratulations. You have succeeded in completely stumping me on this one. My fall back response is to say that the problem is more than likely one of the items that we have already discussed. Good luck.
well after putting in the dry gas i am able to get it to start and idle at about 1500 rpms on its own but now when ever you try to give it gas it just bogs right down and stahls.......i have not yet hooked back up the alternator and the battery has a weak charge....could that be the problem...
You are making progress in having the engine idling. Is it misfiring at idle or running rough? Do you think that bad gas was originally preventing the engine from starting? If so, you may want to drain the tank as mk378 suggested.
What happens if you disconnect the O2 sensor?
You may also want to measure the fuel pressure. Is the vacuum hose for the fuel pressure regulator connected?
