No Brake Resistance
Old Jul 11, 2008 | 05:09 PM
bugbite's Avatar
Default No Brake Resistance
When attempting to change the brake pads on my 95 Civic, I accidentally loosened the bleeder screw and lost brake fluid. I tightened the screw to stop the leaking and filled the reservoir to the max with brake fluid, but now my brakes have zero resistance. I pretty much have no brakes. How do I fix this? Must I bleed the brakes? Thanks in advance for your help.
Old Jul 11, 2008 | 05:17 PM
Default RE: No Brake Resistance
Yes, you need to bleed the system of the trapped air.
Old Jul 11, 2008 | 10:21 PM
cyberx32's Avatar
Did you pump the brakes a couple of times?
Old Jul 12, 2008 | 06:48 AM
If the reservoir ever runs dry for whatever reason, you will have to bleed the whole system.
Old Jul 13, 2008 | 07:12 AM
SilverSedan's Avatar
Actually its probably a combination of two things. 1) first pump up your brakes (engine running, in park/neutral) do it slowly. This is to first make sure you've pushed the pads flat against the rotor. 2) have a buddy help you bleed the brakes (search, there is a proceedure on here somewhere). Should be as good as new.
Just curious how you accidently loosened the bleeder screw tho...usually those things are tight and rusted in...
Old Jul 13, 2008 | 11:02 AM
lol. ya just bleed the system. and ya might as well do the whole system. every wheel. start from rear passenger, rear drivers, passenger front, and drivers front. bleed the system till the brake fluid is as clear as brand new. just keep refilling the brake fluid and dont let it run dry!
waxenol
Sep 4, 2007 07:42 AM
darkneck
Apr 23, 2007 08:38 PM
sbg20307
Jan 10, 2007 10:48 PM
madjoker14
Nov 17, 2006 07:52 PM
arm97002
Sep 6, 2006 10:33 PM
