No Heat
Old Aug 16, 2005 | 06:17 PM
hondanewfie's Avatar
Default No Heat
I have a 93 Civic that I put a new rad in about 6 months ago. If I want any heat at all right now I have to put the switch on recirc and I get a little. I hardly get any heat any other way. Thermostat maybe?? Any help would be appreciated.
Handanewfie
Old Aug 16, 2005 | 06:45 PM
StifflersMom's Avatar
Cat Fuсker
Default RE: No Heat
If your temp. gauge is low all the time, than yes, it's probably stuck in open cycle. Had that when bought the car...
Old Aug 16, 2005 | 07:06 PM
ngoti 8tor's Avatar
Default RE: No Heat
Sounds like you need a new thermostat. Does the engine overheat at all?
Old Aug 16, 2005 | 08:03 PM
Default RE: No Heat
no it doesn't overheat. Just not alot of heat in side.
Old Aug 16, 2005 | 10:43 PM
sacicons's Avatar
Default RE: No Heat
its probably low on coolant. check that first.
Old Aug 17, 2005 | 09:39 AM
ngoti 8tor's Avatar
Default RE: No Heat
Hehehe, thanks sacicons, I guess I missed that one!
I thought that's what anyone woulda done first off, but hey, I guess some people don't.
Old Aug 17, 2005 | 11:56 AM
jake11375's Avatar
Default RE: No Heat
Sounds like either your thermostat or your relay switch. So what does your temperature guage read after the car has warmed up?
Old Nov 11, 2005 | 10:30 AM
caper10's Avatar
Default RE: No Heat
I'm having the same problem with my 95 Cx. I picked up a new thermostat it's rated at 177 deg. Is this the correct temprature for this car...seems rather low to me. I always remember putting in 195 deg in the winter with other cars. The temp gauge in the car doesn't move off of cold.
Thanks
Old Nov 11, 2005 | 09:54 PM
sacicons's Avatar
Default RE: No Heat
normal is 180*, so 177 is fine. is your coolant level low? how long do you drive it without it moving off of low?
Old Nov 12, 2005 | 05:38 AM
caper10's Avatar
Default RE: No Heat
I'm going to change the tstat today...coolent level is ok...new rad...drive for 30km and still gauge hasn't moved
