HondaCivicForum.com
-   -   no power to obd2 port (https://www.hondacivicforum.com/forum/mechanical-problems-technical-chat-8/no-power-obd2-port-58407/)
sto73 Jan 6, 2008 01:59 PM
my 01 civic lx has a cel and i have my own scanner but when i plug it in nothing happens. it should light right up and start reading, but i get nothing. is there a fuse or something that i dont know about? i thought it was connected directly to the ecu.
RonJ Jan 6, 2008 02:10 PM
RE: no power to obd2 port
Check fuse 9 in the under-hood fuse relay/box (see picture). Note that multiple other functions would also be lost if fuse 9 were blown.
http://img231.imageshack.us/img231/7...ure0308ek0.jpg
sto73 Jan 6, 2008 03:29 PM
fuse no9 is good i think i may have lost the ground, anyone have any idea where to find that?
RonJ Jan 6, 2008 03:38 PM
The manual for your code reader may show a diagram of the data link connector (DLC), where you can determine which terminal supplies battery power. With this information, you can use a multimeter or test light to directly test whether your car's DLC is receiving battery power. If so, the problem might be your code reader.
RonJ Jan 6, 2008 03:44 PM
ORIGINAL: sto73
See picture. Again, it may be helpful that the same ground is shared by several other components.
http://img218.imageshack.us/img218/4...ure0312db4.jpg
sto73 Jan 6, 2008 04:05 PM
my code reader is good i just used it on my wifes car to check it. as for shared grounds my car is m/t and have no heated seats. i did have my center console out today installing a new shifter boot, i may have knocked something loose, but i dont think i did.
RonJ Jan 6, 2008 04:14 PM
Edit: Comment deleted - your previous post answered the questions.
