No response from my idle screw?? 1992 civic
I have a Honda civic 1992 1.5 engine. I have been experiencing an unusually low idle while the car is in drive and hot. While accelerating I also experience a sputtering from a stop position. These symptoms have gradually become worse over the last two weeks. My ignition system was replaced approximately a year ago. WHen I replaced all my plugs and wires I tried to ajust the idle screw with barely any response from it, today I again attemped to ajust and still very little increase or decrease. I'm kind of out of ideas without replacing piece by piece. Any ideas or help would be greatly appreciated.
Is the CEL ON?
Besides the plugs and wires, did you also replace the distributor cap and rotor? If so, the next step would be to clean the IACV (EACV) on the throttle body. Click the IACV link in my signature.
Yes I replaced the cap and rotor and the speed does drop when the plug is pulled on the IACV (with engine hot). I removed the FITV (with engine hot)and noticed an unusually high vacuum from the lower port inside the the air intake. does FITV have anything to do with the idle if so is there a test to determine when to change The fitv??
Yes, FITV has to do with idle. However, a faulty FITV would cause surging and an abnormally high idle.
The idle adjustment screw doesn't make very noticeable changes when you turn it. The changes are very subtle.
