what order do the spark plug wires go?
Old 09-10-2006, 01:26 PM
skatingsamurai's Avatar
Default what order do the spark plug wires go?
im doing some work on my friends civic sohc (im an rx7 guy) its a 95, and i was just wondering what order the spark plug wires should be attached to the distributer cap? one other thing that was wondering is, where can i find a diagram for the fuel system? i need to replace the fuel filter but i cant find the fuel pump. (im asuming that the procedure would be similar to that of diconnecting the fuel pump wires in my fc. thanks ahead.
steve
and if any of you are wondering, my car is a 87 t2 with s5 turbo and mani and a **** load of other stuff (maybe like 5k worth)
Old 09-10-2006, 01:28 PM
finalimpact's Avatar
Default RE: what order do the spark plug wires go?
firing order goes 1-3-4-2 #1 being the closest to the tming belt
distributor order goes as
3-4
1-2 looking directly at the cap with the distributor on the engine
fuel pump is in the fuel tank and can be accessed under the rear seat.
Old 09-10-2006, 01:35 PM
oh and more info and pics of your t2 would be nice.........ive always wanted a t2 as i love the body styling. hey its the least you could do for me helpin you out
Old 09-10-2006, 02:18 PM
alright im still confused. i dont know what the orientation of the distributer is...or mayba try explaining is a different way
thanks
ans ill get the pics up as soon as i have finished wit this
Old 09-10-2006, 03:36 PM
ok i put the plugs in but when i start up the car is sounds like its spuddering... like its really WEAK and unreasponsive. whenever i give it gas there is a back fire then it slowly revs, but not as fast as it should. anyone know?
steve
Old 09-10-2006, 04:19 PM
fglaustin's Avatar
check the timing.
sounds like one of the wires is not attached.
did you gap the plugs
Old 09-11-2006, 12:25 AM
i beleive i explained it wrong lol
Old 09-11-2006, 01:13 AM
deserthonda's Avatar
if you need to replace the fuel filter why do you want to know where the fuel pump is located???
the filter is located under the hood on the firewall....... just remove the gas cap to relieve the pressure then replace the filter .. very easy job
smokingemcee
05-17-2005 08:15 PM
fast93civic
02-05-2005 04:47 PM
bulletman0_0
11-08-2004 11:17 PM
civic1.5uk
07-24-2004 03:15 PM
Quick Reply: what order do the spark plug wires go?
