Noise coming from engine, squeaking(video inside)
Do you have a mechanic's stethescope? That may help to isolate the source of the noise.
Is the power steering reservoir full? Sounds like the pump running dry. (If you need to add some, use only Honda fluid or some that is specifically labeled as suitable for Honda, not generic power steering fluid).
If it's not that, take all the belts off and spin the alternator, etc. by hand. It should be apparent which one is making noise. If it's not one of those, start the engine with the belts off, if still noisy it is something related to the timing belt. |
Power steering pump wheel looks like if it was loose or something, it is moving sideways and up/down. Or is it just the video?
yeah it was moving sideways, someone else said it was the powersteering pulley that was lose. imma tighten it and see if thats it. then do the alt, and yeah power steering pump is full.
