noise in the front passenger side
hello i have a 1996 honda civic ex. when i go around a corner there is a noise shakes and i can feel it in the steering wheel only when i go around a corner. i just put a new cv joint in that side.
i have to change out my rotors cause they are warped . would this cause this problem?
Warped rotors could cause vibration in the steering wheel. Start by changing out the rotors since you already know you need to. If it doesn't fix it, well you fixed the rotor problem so that's good... go from there.
| All times are GMT -8. The time now is 03:38 AM. |
