Noise from rear pass wheel
Old May 13, 2006 | 03:12 PM
gwl's Avatar
gwl
Default Noise from rear pass wheel
Sometimes when I drive my 97 Civic I can hear a slight clunking sound from the rear right wheel. I can hear the same sound if I grab both sides of the wheel and pull back and forth. I can't seem to find the source of the problem. Also, when I jack the car up I cannot duplicate the problem.
Thanks in advance.
Glenn
Old May 13, 2006 | 07:16 PM
my_hidden_romance's Avatar
Default RE: Noise from rear pass wheel
have u tightened ur lugs??
if you have.. and its still persisting.. it could be ur axle is loose.. or maybe ur strut is needing replaced.. those would be my guesses
Old May 13, 2006 | 07:36 PM
AgentofDarkness's Avatar
ORIGINAL: my_hidden_romance
Civics are front wheel drive, so the rear passenger wheel would not have an axle connected to it. If the strut was bad, when you push the back of the car down a couple times the problem should happen again. Also, take the wheels off and inspect the strut, if you see any fluid around the strut then it is leaking and you would have to change it.
Old May 13, 2006 | 08:05 PM
theres a non fuctional axle?? supporting that rear wheel.. allowing it to turn.. thats what i meant..
Old May 13, 2006 | 08:34 PM
gwl's Avatar
gwl
I don't see any fluid around the strut and I made sure that my lugs are tight. I thought the lugs were loose too because I did a brake job a couple weeks ago. Today, I had a chance to take another peek at it, I remove the wheel and try to recreate the noise but I was unable to budge it. I still have the noise when I remounted the tire with car on the ground. Strange isn't it???
Old May 13, 2006 | 09:34 PM
rear brakes.. did u set the pad right in the drum?? maybe theres something loose there.. does ur ebrake work?
Old May 13, 2006 | 09:59 PM
gwl's Avatar
gwl
My e-brake works because they will lockup when I only pull the e-brake to stop the car. I don't think I assembled the brakes incorrectly. I will have to double check it in the morning to see what is wrong. The amount of movement in the wheel is very slight when I pull on it. I probably use two jacks, one for the car and the other one just to jack up the wheel assembly.
Swater96
Jul 17, 2013 03:51 PM
Tinkerbell_too
Oct 6, 2010 05:42 AM
toddcfd23
Jun 12, 2008 10:15 AM
Toppers
14
Apr 17, 2008 06:36 PM
Civi23
Mar 7, 2007 04:32 AM
