Noise when I turn the wheel
Old Dec 29, 2011 | 06:12 AM
jaybbie17's Avatar
Default Noise when I turn the wheel
hi sir. I have a problem with my steering wheel. Everytime i turn the wheel, i can hear a noise . I have already bleed and replace the transmission fluid. And just this day, i also changed the swing arm bushing, as advised by the mechanic that it was the reason causing that noise. When i test the car, the noise was gone, unfortunately, after driving a few kilometers going home, the noise was again present.
Its really quite expensive going in and out of the shop, seems that everything is on guesing, where they really can detect what's the problem really is.
Now i doubt, it might be that tin covering the front disc brake banging with something. please help
Old Dec 30, 2011 | 06:43 AM
paj's Avatar
paj
Default re noise
hi,
I had this sort of problem with the back plate/splash guard which was badly corroded. Also check brakepads some have a protrusion to warn they are nearly worn out, these can make a real din intermittently at first. Another possible is a stone or grit trapped somewhere. I hope this info may be of some help.
cheers paj.
dlion77
Jan 23, 2010 09:03 AM
jpnolan
Apr 14, 2009 11:11 AM
TheGodfather
Dec 21, 2006 10:16 AM
96civichb
Dec 16, 2006 01:31 PM
superso
Jun 1, 2005 07:39 PM
