O2 sensor
Old Oct 13, 2010 | 06:37 PM
Jason D's Avatar
Default O2 sensor
what is the difference between the up stream and down stream sensor? and are they basicly the same sensor?
Old Oct 14, 2010 | 06:59 AM
Upstream sensor is before the catalytic converter, and downstream is after. The first one provides feedback for the ECU to control the fuel-air mixture. The second one is used only to check converter performance. On some models they are the same part type and on others they are different.
Old Oct 14, 2010 | 08:19 AM
Jason D's Avatar
ok thank you. i have a O2 sensor bad and i have a new one but its up stream and the one that is bad is down stream. just didnt know if it would work
addiction2bass
Aug 14, 2008 09:53 PM
fglaustin
Mar 27, 2008 08:29 PM
vtec02
May 9, 2007 05:17 AM
00sithrottle
May 12, 2005 10:25 AM
