OBDII P0715
Hi,
Check Engine Lamp came on last week in my 97 Civic EX, I took it to dealer this week trying to make use of my extended Emission warranty. But they say the code P0715 is not an emission related problem and hence my extended warranty will not cover it. They suggested to do following 3 in order: Transmission refill 80$ Replace transmission linear Solenoid 266$ Replace transmission 4300$ Any suggestins, what should I do? Thanks |
RE: OBDII P0715
Here is what I found out using my FSM for the 96-98 civic.
See the following photo labeled the P0175 code: http://good-times.webshots.com/album/563221127praaCY |
RE: OBDII P0715
wow 4300 for a transmission? thats why i dont go to dealers
RE: OBDII P0715
3 Attachment(s)
It's an automatic transmission trouble code. Here's what the manual says:
Attachment 26979 Attachment 26980 Attachment 26981 |
RE: OBDII P0715
Does any of these repairs come under Emission warranty as I got a letter from HOnda sometime back saying that Federal Emission Warranty for my car is increased to 15 years and anyting covered under Emission Warranty will be diagnosed/repaired free of cost.
Can I get a dealer to fix it under warranty? Following is covered under Emission warranty (from http://www.ahm-ownerlink.com/Documen...s/awl17925.pdf) Fuel Injection System • Engine Control Module (ECM). 8/80 • Fuel injectors. • Fuel rail. • MAP sensor. • Heated oxygen sensors. • Oxygen sensors. • Barometric pressure sensor. • Intake air temperature sensor. • Throttle position sensor. • Engine coolant temperature sensor. • Knock sensors. • Powertrain control module. 8/80 • Transmission control module. • Countershaft speed sensor. • Vehicle speed sensor. • Fuel pressure regulator. • Fuel pressure regulator vacuum switching valve. • Idle air control valve (IACV). • A/T gear position switch. • Lock-up clutch control solenoid valve. • Shift control solenoid valve. • Fuel filter (covered up to the first replacement only; see the maintenance schedule in the Owner’s Manual). (Fuel filter replacement and flushing of the fuel tank to remove contamination resulting from a defect in material or workmanship only are covered by the warranty. Fuel injection system cleaning is covered.) Intake Air System • Air cleaner element, housing, and cover (covered up to the first required replacement only; see the maintenance schedule in the Owner’s Manual). • Mass air flow sensor. • Air regulator. • Common chamber. • Throttle body assembly. • Throttle switch. • Intake manifold. VTEC System • Variable valve timing & valve lift electronic control solenoid valve. • Variable valve timing & valve lift electronic control pressure switch. Miscellaneous Parts Hoses, clamps, brackets, piping, bolts and gaskets associated with these systems. |
RE: OBDII P0715
Can I get a dealer to fix it under warranty? |
RE: OBDII P0715
As per the troubleshotting chart posted it seems to be a problem with the mainshaft speed sensor and it seems to be covered by extended warranty.
So i will go to delaer and ask again if it can be fixed under warranty but I doubt so as they gave me wrong info earlier something realted to Linear Solnoid on trnasmission |
RE: OBDII P0715
You may have a better chance with the dealer now that you have more detailed information. Print out all relevant information and bring it with you.
RE: OBDII P0715
Thanks for the info I will go to delaer with all the info tomorrow and post the result back here
RE: OBDII P0715
So I went to the dealer again armed with all the info which i got here and they replaced the Linear Solenoid valve under warranty without any charge to me.
Thanks guys.!! |
| All times are GMT -8. The time now is 06:03 AM. |
