Odd headlight problem....Any ideas?
Old Jun 10, 2008 | 05:16 AM
dave_57204's Avatar
Default Odd headlight problem....Any ideas?
Hey,
I have a 99 honda civic lx, the right headlight does not work on the normal beams but the high beam works. If I open the hood and tap the headlight plug it ussually comes back on but it will go back out once I start driving (Anywhere from 5 minutes to an hour) anyone have any ideas? I havent had a chance to look at it yet its been to hot outside lately (100+ I can't take the heat, winter ftw) Thanks for any help!
Old Jun 10, 2008 | 05:55 AM
Default RE: Odd headlight problem....Any ideas?
Try a new bulb first. That's the general rule anytime a light doesn't work. They can get so the filament is broken but it touches back together when you tap on it.
Old Jun 10, 2008 | 08:24 AM
sLyda's Avatar
check the fuses also, i had a similar problem on my civic but it turns out that the fuse was blown.
Old Jun 10, 2008 | 10:49 AM
well if it works when ya bump it id say theres 2-3 posiblities... one bad bulb. just has a busted filement or busted metal prong internaly maybe....
2nd might be busted wire on the wire plug that goes onto the headlights or even just dirty.
to see if its a wire problem just lightly push and pull on the wires on the plug trying not to push or pull to hard... and if the light comes ON and OFF then its a busted wire on the plug. either replace the plug or just cut the wires and crimp on some spade terminal wires and plug them directly onto the bulb.
Old Jun 10, 2008 | 10:51 AM
Old Jun 10, 2008 | 10:54 AM
also replace both the bulbs so they match! if you do buy new bulbs
Old Jun 10, 2008 | 05:52 PM
dahuckman15's Avatar
i had a similar problem after i rearended someone and took it to a shop. turned out the wiring had a poor connection and was still frayed from the accident. simply check the fuses, wires, and bulbs and your problem should be solved.
Old Jun 10, 2008 | 10:03 PM
dave_57204's Avatar
Allright thanks for the info, Should be cooling down tommrow gonna check it out. I'll let ya know how it turns out.
Old Jun 11, 2008 | 08:45 AM
i agree it's probably just the bulb, but...
check your plug that plugs into the bulb for corrosion.
dabflyboy
Feb 20, 2009 08:13 AM
01silverbullet
Jul 23, 2006 06:08 PM
solewheelin
Jul 7, 2006 07:18 AM
ten2doyle102
Oct 17, 2005 10:16 AM
Cyrano
Jun 24, 2005 08:41 PM
