Oil Lamp coming on when car is cold
Old Apr 14, 2014 | 12:33 AM
Xirley's Avatar
Question Oil Lamp coming on when car is cold
Hi everyone, I have an issue with my Honda Civic. It’s a 2008 Civic, 2.2 TDI. I recently bought second hand from the Honda Showroom so its new to me (only had it for a week). Whenever I park the car outdoors overnight, the oil lamp lights up in the morning once or twice for the first 5 minutes of driving time then it doesn’t come on again. Whenever it is parked in a garage I never have this issue. I came to the conclusion that it does it until the oil warms up. Are my assumptions correct? I had the oil checked last week and it was just below minimum so I had it topped up since and the Honda mechanics checked the oil pump and there are no leaks. They were quite confused by it and had the car reset. Any thoughts on why the oil lamp lights up on cold mornings? Is this common? Thanks to all
Old Apr 15, 2014 | 07:24 PM
You may want to change the oil and filter to be sure that the correct viscosity of oil is in the engine, and that the filter is not clogged. Did the dealer do that just before you bought the car?
Generally when the engine is worn, oil pressure is more prone to drop too low when it is hot, because the oil gets thinner. So this is kind of an odd problem. Sometimes (very rarely) the switch for the warning light is bad or there is a short in the wiring, causing false alarms.
joegruber
Jan 8, 2014 04:31 AM
allisaurusrex19
May 21, 2013 08:34 PM
oilltd
Jun 10, 2008 04:06 PM
nemo
Dec 11, 2005 03:51 AM
